2003 polaris magnum 330 4x4
Old Dec 14, 2021 | 03:47 PM
marcs1969's Avatar
Default 2003 polaris magnum 330 4x4
My circuit breaker (in the black pouch) keeps tripping when I cut ignition on. ATV will run for a few seconds until it gets hot. I have changed out ignition switch, solenoid, ECM, volt reg, inline fuses, and another electrical component(not sure what it is). These exchanges come from a running 330. Any ideas thanks
Old Dec 17, 2021 | 06:24 PM
Yooper265's Avatar
Have you replaced the 20 amp breaker ? They do go bad .
Do you have / need the service manual with wiring diagrams for this ? I have it if you want it .
Old Dec 19, 2021 | 06:50 PM
marcs1969's Avatar
Default Polaris magnum 330
I have replaced the 20 amp breaker but didn't fix it. I disconnected the shift linkage and manually made sure I was in park and problem solved. I hope! Now motor revving higher than before and not sure why. One more problem to look at. Thanks
joenat
Oct 28, 2020 09:02 AM
eboy
Jul 21, 2014 04:18 PM
isuagstud
Jul 16, 2014 10:24 PM
