2003 polaris magnum 330 4x4
My circuit breaker (in the black pouch) keeps tripping when I cut ignition on. ATV will run for a few seconds until it gets hot. I have changed out ignition switch, solenoid, ECM, volt reg, inline fuses, and another electrical component(not sure what it is). These exchanges come from a running 330. Any ideas thanks
I have replaced the 20 amp breaker but didn't fix it. I disconnected the shift linkage and manually made sure I was in park and problem solved. I hope! Now motor revving higher than before and not sure why. One more problem to look at. Thanks
