Gio Swing Arm bushings options.
Old Mar 21, 2022 | 09:39 AM
Uroslut's Avatar
Default Gio Swing Arm bushings options.
So basically in process of rebuilding this atv for fun more then anything, its an older Gio Beast 200-250cc(unsure really)
So got it all running well with new carb and wiring harness electrical, and out for a spin.....chain kept popping off.
had a closer look and the swing arm is noticeably loose and allows play in the rear end enough to slacking the chain and pop it off.
Took it all apart and noticed it has good nylon or Poly bushings on frame side but nothing but bare metal in the actual swingarm. I measured the holes and they are 12.5mm big on the swing arm and the bolt/axle is 12mm
Is there a option for replaceable bushings in the swing arm?
I am looking for any options you all might have encountered, including boring the swing arm holes larger and installing some larger bushings etc.
Anything, want to get this thing going.
Old Jul 4, 2022 | 10:14 AM
Fullcustom's Avatar
Default Amazon
I found some that I believe will work off Amazon. Thinking they may have been for one side of front as it was a set of 4.. however the measurements match. Honestly I used a 1/2 inch piece of PVC and pounded metal pieces that fit the bolt into each end while I waited for parts. Worked well enough I haven't put new ones in.
Old Jul 11, 2022 | 09:43 AM
Zrock's Avatar
Super Quad Patrol
When i was playing with those i found complete swing arm that used bearings instead of bushing.. Took alot of time searching and measuring
Uroslut
2) Chassis problems..
Mar 21, 2022 09:30 AM
KTM265
Feb 7, 2007 02:49 AM
JEFFROE
Jul 22, 2005 04:00 PM
AIRtime300ex
Oct 29, 2000 10:22 PM
