Electric start problems
Old May 2, 2022 | 11:15 PM
dawson882's Avatar
Default Electric start problems
I have 1983 atc200e that I recently picked up and the electric start most of the time doesn’t work. It’s weird I’ll ride it for a bit and when I park it and go to ride again the electric start will work but most of the time it won’t the button just won’t engage anything. I took apart my button and it was all intact. Is there a ground that maybe isn’t getting a good connection or is this a sign my solenoid/relay is on its way out? Appreciate any info
Old May 3, 2022 | 05:29 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
By no means an electrical expert, but if it keeps going back and forth, I'd say it's definitely a loose wire. I'd check the negative wire from the switch all the way back to the ground on the battery.
Old May 12, 2022 | 05:07 PM
catchmeifucan's Avatar
Also not an expert but I would start by following the wires looking for damage or corrosion. Make sure grounds are making contact and everything is tight.
Jp91
Nov 3, 2021 03:29 AM
atvpredrider500
Dec 23, 2012 05:27 PM
rgall
Jul 15, 2007 09:13 PM
