1996 polaris 425 magnum 4x4-spark but will not fire
Old Dec 30, 2022 | 01:20 PM
Aljanssen's Avatar
Default 1996 polaris 425 magnum 4x4-spark but will not fire
Stator and trigger coil ohm out as they should. Have checked camshaft and valve adjustment, all ok. Has spark but will not fire even with a shot of brake clean. Have repkaced the spark plug. Primary coil reads 0.5 ohms in spec. Secondary reads 3k ohm ground to coil screw for plug lead. Out of spec but have spark. Not sure if spark is strong enough. Could the coil be the issue?
Old Jan 1, 2023 | 11:59 AM
Aljanssen's Avatar
Default Trigger gap
Turns out trigger gap was at over .060, spec .016 to .040. Not adjustable. Ground off locating tabs, elongated mounting holes and set gap at .022. Reassembled and spark will now jump a 5/8" gap. Unit now starts as it never has! Had spark but would not fire under compression.
Gubby500
12
Oct 25, 2017 08:17 AM
joethegasman
17
Jul 4, 2017 05:07 AM
mbweido3
Nov 4, 2008 12:51 AM
firefighter781
Feb 20, 2007 01:50 PM
BIGREDRIDER2233
ATC 3-Wheelers
12
Feb 3, 2007 12:12 PM
