Pz19 carb upgrade
Old Jan 24, 2023 | 08:50 PM
Tatertot58's Avatar
GirlDad
Default Pz19 carb upgrade
I have a Kayo Fox 70 I have ported and polished the head kind of aggressively, and welded up a fmf header and muffler. I’m starving for fuel with the pz19. Changed jets. Better but Not enough still. I need at least a pz20 but want to go pwk style would a 22mm be too much?
Old Jan 25, 2023 | 03:50 AM
I'm no engine tuner, but bigger jets give you a richer mixture, so more fuel. A bigger carb gives you more mixture, so if an engine is run full throttle and tops out on revs, a bigger carb will give more revs if ports etc, allow. It won't give a richer mixture without bigger jets too. Overly big carbs however, slow the air speed through the carb so it isn't sucking fuel through the jets as hard and will give a weaker mixture, so less fuel.
Old Jan 25, 2023 | 03:51 PM
Tatertot58's Avatar
GirlDad
Thank you that was the best explanation I have ever heard. It all makes sense now thank you for that
kelly w
1) Engine problems..
Sep 30, 2014 06:51 AM
tangmu12
Jan 13, 2009 04:57 PM
madhatter801
Oct 14, 2003 06:54 AM
