Polaris Magnum 325 Bogging.
Old Mar 2, 2023 | 02:13 PM
Mark231's Avatar
Default Polaris Magnum 325 Bogging.
I have a Polaris Magnum 325 I am trying to fix up for my neighbor. It will sit and idle great. Once your about 1/2 throtle it starts to bogg. The carb is spotless, cleaned with my ultra sonic cleaner and for good measure I soaked it with carb cleaner for 2 days. New All ***** carb kit installed, mixture at 2-1/2 turns out. New spark plug. Drained the fuel tank, fresh fuel. Even tryed running it from a remote fuel source omitting the fuel tank and fuel pump. Still boggs. It does have a new aftermarket foam air filter installed, wondering if it's too much restriction compared to the paper air filter. If I run it with the air box lid off it seems to run 100% better. I am going to check the compression and valve adjust next. Any help you can give me would be greatly appreciated.
Thanks
Mark
Old Mar 2, 2023 | 08:17 PM
nny's Avatar
nny
So try the paper filter see if that changes anything. Checking valves is a good next step. While your at it check your timing and your chain tensioner.
Old Mar 3, 2023 | 08:23 AM
Mark231's Avatar
Compression was at 160 psi and the valves within spec. I don't have the stock paper air filter as it was thrown away.
Thanks
Yost_Face
Nov 22, 2021 10:07 AM
dan.ellsweig@gmail.com
Apr 6, 2020 08:56 AM
skidaddyrickus
Feb 13, 2020 10:04 AM
ConnorC7
Dec 4, 2017 04:58 PM
Snortwheeze
Apr 7, 2008 01:24 AM
