330 Big Bore Requirements
Old May 4, 2001 | 12:03 AM
N3C0T0's Avatar
To All-
I am looking to put in a 330 bore kit in my '01 300EX. Other than re-jetting, what is required for this mod? Is is REQUIRED to put an aftermarket pipe on or to re-gear? Can I wait a bit on the pipe or do I need it before the boring? Thanks for the help.
Old May 4, 2001 | 07:47 PM
Mike300ex's Avatar
No you dont need a pipe or anything else for that matter. BUT don't expect the same results that other guys with pipes/cams/carbs/air filters/rev boxes/etc have. You're not going to be blowing away any 400ex's with just a 330 kit. It's the combination of parts that makes the power, not just one part alone.
To answer your question, yes you can wait for those parts and you can do it little by little.
Old May 5, 2001 | 11:48 AM
94DGblaster's Avatar
REQUIRED to make a 330
sleeve
piston kit
That will give you a 330cc motor
But for it to run like a true 330cc you need
Sleeve
Piston Kit
Porting, Polish
3 angle valve job
Cam
Valve Springs
CDI mod
Hard weld Rockers
Complete Exhuast System
Bigger Carb
Rejetting
Uni Filter(only because thats what i choose, K&N works some what...if they actually do filter)
So now your motor is up to par.
Now for your bike.
Better Shocks
Longer A-arms
Longer Axle
Then you will be out there with modded 400exs.
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
