1990 Big bear 350 4x4 Oil seal
I am having a problem with excess oil getting into my middle gear drive. 1990 Yamaha big bear 350 4x4. When I remove the fill cap to the middle gear box, oil just starts poring out. When I change the oil, I put the right amount in the middle gear drive the manual calls for, and it is fine. I run the atv for a minute then shut it off and let it sit for a couple of minutes. Then When I open the fill cap, oil starts gushing out. l I am assuming there is a seal or O-ring that is worn between the crankcase and the middle gear drive that is letting more oil overfill it. I have looked up part diagrams and a couple videos (not many videos out there on this machine), but not seeing anywhere how it could overfill from crankcase to middle gear drive. Any ideas where this seal is or how to get to it? Thanks
If it is not peeing oil from the seals for front and rear propshafts, I wouldn't worry about it. If it is the model I think it is, removing that angle drive is a pig of a job, and I seem to recall, most that I used to service, had the drive gear full and overflowing. I can't see any seals between gearbox and angle drive on parts drawings anyway.
Spoiler
bossman0924
Dec 18, 2006 12:29 AM
