94 Suzuki quad runner 250
Old Feb 6, 2024 | 08:19 AM
shankathome@comcast.net's Avatar
Default 94 Suzuki quad runner 250
Hi, just wanted opinions as to how to straighten right side rear is slightly bent inwards look at my pics ?
Old Feb 8, 2024 | 03:31 AM
Check the frame where the A Arm mounts to it, if the mountings are bent you will have to try to get them straight. However most of the bend will probably be in the A Arm, and finding a used replacement will be the cheapest and easiest option, as getting one of them straight again is a bit of a nightmare. "Swinging half axle" type suspensions always do tend to lean in or out though, and a weaker or stronger rear spring alters the lean considerably. Be sure it isn't that before changing an arm.
Old Feb 9, 2024 | 04:24 AM
To make the RH side wheel more vertical you turn the spring adjuster anti clockwise, so the collar sits further down on the snail cam pegs.
Mikeir6
Aug 25, 2018 07:38 PM
Vamp S Triss
Apr 9, 2016 07:52 AM
Mr. Fancy Pants
Worst Stuck Photos
11
Mar 26, 2010 08:15 PM
elasesino
Oct 26, 2008 01:31 PM
outofline
Jul 27, 2008 10:02 PM
