Polaris Scrambler 400 Electrical Issue
Old Jun 13, 2025 | 03:00 AM
troach's Avatar
Default Polaris Scrambler 400 Electrical Issue
Hey, first post on this forum because im stumped. If anyone could explain how the wiring works on the 93 scrambler 400 4x4 auto because i let it sit for a while and just got back into it, replaced the battery and have no power. Im trying to run a multimeter at the wires up near the front but im concerned if theres like breakers or fuses that could be popped or damaged coming from the battery because im getting no power up front at all. Also, could anyone check my wiring on the starter solenoid, i replaced it before i let it sit because it wasnt working and I think I messed it up. Thanks
Battery
Battery
Starter solenoid
Starter solenoid
Wires
Wires
Old Jun 13, 2025 | 10:01 AM
Red64's Avatar
Default Solenoid
No that does not look correct. I have never seen someone run a cable from one lug of the solenoid to the other lug ever. The solenoid is basically a switch. It gets power in and sends power out. Normally you will have a line from the battery to the solenoid them from the solenoid to the starter.
Old Jun 13, 2025 | 10:02 AM
Red64's Avatar
Default Manual
I suggest you get a service manual for your machine and follow the wiring diagrams. There are many things that can be wrong and need to be checked but you can not do that without a manual.
Old Jun 13, 2025 | 10:45 AM
troach's Avatar
Default Reply
Thanks i appreciate the help, I figured everything out this morning and did some tests and my starters probably out. Also, my pull start cable snapped so im going to try and get a new cable for it just to be able to start it. Thanks!
Rsisnew3034
Sep 7, 2024 07:20 AM
Chocobamofo
Jul 10, 2015 07:46 PM
Sladester2
Jun 3, 2013 02:56 PM
djcheez
Sep 29, 2011 11:26 PM
jimmypsp700
Sep 13, 2004 03:35 AM
