Scrambler 500 starting problems
Old May 31, 2013 | 04:34 PM
Sladester2's Avatar
Default Scrambler 500 starting problems
New battery and checked all the connections, they were good, sometimes it will start with the turn key perfectly and sometimes it will just click like a dead battery but the headlights are bright. Any idea what it could be?
Old May 31, 2013 | 04:40 PM
440exbigbore's Avatar
Could it be your starter solenoid? idk I'm just spit balling here..
Old May 31, 2013 | 04:44 PM
Sladester2's Avatar
Idk, It is a weird issue, I thought it may be but wanted some opinions before replacing it.
Old May 31, 2013 | 04:50 PM
have you done the arc trick to it? if it doesn't work, it's definitely your solenoid
Old May 31, 2013 | 04:57 PM
How to Test the Solenoid on an ATV | eHow
a good way to test
Old May 31, 2013 | 05:19 PM
Check that battery and solenoid connections are tight. If it's getting power through the solenoid to the starter,then possible starter brush wear or bendix problem. Cheap enough here if it is a starter/bendix just to replace it. DB Electrical - Scrambler
Old May 31, 2013 | 05:47 PM
Sladester2's Avatar
Will do, thanks!
Old Jun 3, 2013 | 01:46 PM
Sladester2's Avatar
Tapping on the starter with a hammer and it will work
Old Jun 3, 2013 | 02:56 PM
This just confirms either the starter is dirty,bushes worn,or you may have a flat spot on the armature shaft causing it to stick. When you tap on the starter you can "unstick" it for awhile,but they usually just end up sticking again.Cheap as they are now it's not worth it imo to tear one apart,replace brushes,etc as they usually don't hold up.We even sent old starters out and had a generator shop turn the armatures and clean em up and rebuild em,but quit doing this after more than half quit working after a few months.
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
hoopduerr
Jun 1, 2015 08:22 PM
1000gade
May 27, 2015 12:37 PM
