Oh great honda 3 wheeler god.... Does anyone know what valve settings are and if you reset cam chain runing or with engine off.
Old May 7, 2001 | 01:02 PM
realoldguy's Avatar
Please help... used to work on honda at local honda shop years ago and now helping out friend and forget settings on 1985 185.... need valve settings and can't remember if ajust cam chain... is just loosen bolt while running or what....
help
thanks in advance
realoldguy
2001 Scrambler 400
2001 Trailblazer
2001 Explore 250 4X4
2001 Honda 250EX
Old May 7, 2001 | 05:41 PM
sAyIt_fmf's Avatar
Not sure of the valve settings. But I do not think that I would loosen or slacken the timing chain while the engine is running...the last thing you want to do is slip that chain and rip a tooth off the top or bottom. Metal in engine..bad.
Old May 8, 2001 | 12:25 AM
mawr's Avatar
Don't know about the 185 but the '84 ATC 200X required the you hook up a tach and with the engine running at a given RPM you loose a tension bolt on top of the engine case and then retighten. The timing has just been set. Don't know about the valve settings but I have a clymers' manual for the 200X and I believe it has the 185 in it as well. What 185 is it, a ATC 185S? There were a couple so let me know and I will dig out the manual and look up the info
WilliamBos
Jun 11, 2015 05:57 PM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
lovinhonda
Jan 25, 2000 09:17 PM
Joeg
Sep 27, 1999 11:53 AM
