shocks
Old Nov 23, 1999 | 10:14 PM
will's Avatar
I own a 00' 325 Trail Boss and am looking for a aftermarket shock for it because even on small jumps it bottoms out. I have already turned the preload all the way up any help would be appreciated
Old Nov 24, 1999 | 02:39 PM
rooster's Avatar
Will, is it the back shock that's bottoming or the front? If it's the front, maybe Polaris has stiffer springs that you can use, or maybe the coil spring spacers would fit, these are used to increase the lift height on the bigger utility machines when there is a plow mounted, but nonetheless, it increases the stiffness of the shock preload. For the rear, you could upgrade to the Polaris Fox shock, which is used on the Scramblers. This shock has a lot of adjustment on it. Hope this helps.
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
