Sportsman 500 clutches
I see lots of talk about the different clutch set ups and what springs to use but no definatiates on it. As far as belt life and power gain which is the best clutch set up. (by belt life i mean a clutch set up that burns belts off at 1000 miles isn't a good setup
Thanks for any info on the subject.
Donnie Freeze
99 sportsman 500
by the way any one from newbrunswick or maine reading this there is a 3 day run at poly mountain this victoryday long weekend it goes from saturday to monday. each day is on a different set of trails i think i am going to go up to it. I have a silver hjc helmet and of course my Sportsman
Donnie Freeze
99 sportsman 500
WE ALL RUN THE AAEN ROLLER CLUTCH SYSTEM, IT ELIMINATES THE STOCK PLASTIC BUTTONS THAT WEAR OUT WITH BALL BEARINGS, THIS THING ENGAGES RIGHT NOW WITH ALMOST NO LAG. AS FOR BELT LIFE IT LAST JUST AS LONG AS THE STOCK SETUP, MAYBE LONGER. THE KIT USED THE STOCK SPRING ON THE SCRAMBLE 400, AND ON MY SP I CAN'T REMEBER, HOWEVER AAEN'S TECH DEPARTMENT WILL TELL YOU WHAT SPRING AND SETTING TO USE. THIS SETUP FAR SURPASSES ANY OTHER KIT I HAVE EVER TRIED.
