300ex for 250ex
Old May 23, 2001 | 11:11 AM
user101's Avatar
I have a 250ex and it is getting boring to ride. It aint fast enough the suspension on it is bad. I get it stuck all the time. I'm hopefully going to get a 2002 300ex. My odysse is worth 600 (electric start, new airfilter, and pipe). I'm not sure how much my 250 is worth I'm thinking about 3200.
Old May 23, 2001 | 03:38 PM
Honda250exKid's Avatar
Why would you do that? The 300ex has the same top end speed as the 250ex. And you will get stuck even more because the 300ex only has 4.9 inches and the 250ex has 5.9 inches. The only way to make the 300ex faster is get a 330 kit for it.
01 Honda 250EX
00 Yamaha Grizzly 600
Old May 23, 2001 | 04:20 PM
xepathfinder's Avatar
if you are getting stuck it is more than likely a tire issue, you migth not have the right kind of tire for your style of riding, invest in some better rear tires, maybe go up an inch for added ground clearance. Black Waters or Bear Claws seem to be popular for mudding on 2 wheel drive machines. You would be giving up shaft drive for chain drive and not getting any more speed.
Old May 23, 2001 | 04:32 PM
97300exGuy's Avatar
Umm...Actually the 300ex will smoke a 250ex. You are just saying that the 250ex will stay with a 300ex because you have a 250ex. Well I have ridden both and the 300ex has much more power. I have raced a 250ex and I killed it. Infact, we switched 4-wheelers and the 300ex still won. The 250ex is a kiddy machine. It is a utility engine in a sporty frame. The 300ex top speed is between 60-65 around here. Speed depends on conditions a lot of times. A 250ex top speed is beteewn 48-52.
Old May 23, 2001 | 09:03 PM
Muskeg420's Avatar
Excuse me, A 300 ex will kill a 250 ex...What are you smokin man, not a chance, I have both bikes and both are stock, except for K&N air filters on both. Not at any time does the 300 ex kill my 250 ex. Yes the 300 is faster. Yes the suspension is a little better but a stock 300 will only do about 2-3 miles an hour faster than the 250. Dont listen to these people who make assumptions not having ridden both. Im tellin you strait up. Oh and the guy who says his 300 ex will do 65, Sorry Dont think so man. Maybe in the back of your pickup truck...lol
Old May 23, 2001 | 11:24 PM
Need4Speed's Avatar
Actualy 60-65 sounds pretty believeable to me. My X when it was stock was clocked at 61 this winter and no I'm not full of it. It's probly my elevation, that and the cold air makes your bike run better since it runs it leaner.
Old May 24, 2001 | 08:18 AM
skull's Avatar
they are both good bikes for what they are designed for.
are you talking about gettin stuck muddin?
if you like to do muddin, you might just want to stick with the 250ex. just get some aggressive rear tires, but if you like more of a mx type of bike then you would be happier on the manual clutched, chain drivin 300.
Old May 24, 2001 | 08:27 AM
skull's Avatar
there are plenty of other ways of making a 300ex faster without the 330 kit.
example; cam, pipe, port and polish, clutch, and high compression piston.
changing the sprockes alone will make it smoke a 250ex.
Old May 24, 2001 | 08:32 AM
derekhonda's Avatar
gee my 400ex will only go about 63 with my 14 toothed on, i think im gonna sell it and get something faster, like a 300ex
Old May 24, 2001 | 08:34 AM
derekhonda's Avatar
oh and my comparison, weve driven a 250ex next to a truck going down a level road and it hit in the 54-55 range. a 300ex hit 57. i hit 63-64. actually those are all pretty similar figures.
