Jetting for my 300ex
Old May 24, 2001 | 02:45 PM
ex_master's Avatar
What size jets should i run on my 300ex? I'm at sea level i have a k&n filter with no airbox lid , a supertrapp headpipe from an ids2 and a stock silencer with drilled baffels. What should i run for jet sizes?
Old May 24, 2001 | 03:32 PM
bermbanger's Avatar
Really theres probably no way to tell. Its just guess and check. Start out with something like a 140 main and work your way down.
Old May 25, 2001 | 08:41 AM
skull's Avatar
heck, I'd just spend the $45 and get the k&n jet kit. it comes with instuctions on what jet to run with what mods. it tells you what needle settings to run, how much to adjust the air/fuel mixture screw.
yea, you could do it yourself with a days worth of trial and error, but how many jets are you going to have to buy to get it right? how many spark plugs are you going foul-out before you get it right?
Old May 25, 2001 | 09:47 AM
DEPALMA's Avatar
I HAVE A FMF PIPE AND K&N FILTER I JETTED MINE UP TO A 128, I NEVER HAD A PROBLEM OR FOULED A PLUG, YOU CAN ALWAYS ADJUST YOUR MIXER SCREW, IT HAS BEEN A WHILE SINCE I DID THIS I THINK THE STOCK 300 HAS A 124 MAIN JET, I ON MY WAY TO HONDA NOW SO I WILL DOUBLE CHECK, CALL OR E-MAIL SUPER TRAP FMF HELPED ME ADJUST MINE
Old May 25, 2001 | 12:09 PM
DEPALMA's Avatar
SORRY I HAD TO RUN OUT YES MY CARB IS JETTED TO 128 THAT IS WHAT FMF TOLD ME TO DO, NOW K&N TOLD ME 121 WHICH STOCK I WAS AT 124 SO THEY WERE WRONG. I HAD NO PROBLEMS NEVER FOULED A PLUG IT RUNS GREAT, INSTEAD OF TAKING YOUR AIR BOX LID OFF I PUT AIR FILTER PLUGS IN THEY WORK GOOD TO. GOOD LUCK
Old May 26, 2001 | 07:13 AM
skull's Avatar
k&n uses a diffrent set of numbers, maybe thats why the number they gave sounded wrong. all I know is, I never had any experience tearing a carb apart or making any adjustments to it. and with the k&n jet kit I was able to install a pipe, and an outerwears air box lid, then nail the jetting on the first try. and the bike runs beautfully.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
