Banshee Jetting
Old May 30, 2001 | 04:02 PM
BlackIce's Avatar
Ok, this may sound dumb to some of you, but when you are jetting your banshee, do you do both carbs at the same time? Just curious, or do you do one then do the other? thanks a lot
Bryan Maynard
99 Banshee
http://www.phobia.net/~blackice/banshee
Old May 30, 2001 | 04:20 PM
RoostKing's Avatar
Yes, you need to do both carbs with the same size jet...
RoostKing...
Old May 30, 2001 | 04:22 PM
WyoDuner's Avatar
BlackIce, you should jet both at the same time. In fact, anytime you do anything it should be the same for both cylinders. Do you know what size jets you have, what you need and how to change and check the jetting?
Old May 30, 2001 | 05:08 PM
BlackIce's Avatar
Dang...No i dont know what size are in there, i dont know what i need, and im not POSITIVE on how to check the jetting to make sure it is right. Suggestions Wyo? (BTW, since day one you have been a HUGE help to me. thanks a lot...just thought i would throw that in there)
Bryan Maynard
1999 Banshee
Old May 30, 2001 | 05:27 PM
H300F's Avatar
why do you want to jet your banshee? didnt you just get it? it should be fine as long as your arent putting any mods on it, and if it came with mods im sure the x-owner did all the jetting.
i would leave it along, as long as it is running fine.
Old May 30, 2001 | 05:33 PM
BlackIce's Avatar
Yea, im not gonna mess with it...It was just a question for when i do start doing mods. I just was wondering. Thanks though...Im not gonna mess with it... [img]i/expressions/face-icon-small-happy.gif[/img]
Old May 30, 2001 | 06:19 PM
WyoDuner's Avatar
Well, from the pics on your site it looks like it is still stock so chances are that it doesn't need to be jetted. Once you start making mods you are going to have to play with the jetting. Right now though, if it runs well, accelerates well and revs out well don't worry too much. Take out your plugs and see if they are white/black/or tannish colored and that will give you a GENERAL indication of how it's running. They should look tan or chocolate brown colored and not real light or real black. Remember, check both plugs as there is no gurantee that both cylinders are running the same; they should be but who knows. The jets are located inside of each carburator and can be seen by removing the float bowls which is the bottom part of the carb. They are brass, 6mm hex head and have a hole in them with a plastic "thing" surrounding them. It's easy to tell once you open up the carb. I'm not suggesting that you do that now but you will have to sooner or later.
Old May 30, 2001 | 11:41 PM
H300F's Avatar
also, some advice. you said do i do them at the same time...
no jet one at a time. take it off, put the jets in, put it back one. take the other carb off, put jets in, put back on. your done. if you do it this way you will defeat the problem that sometimes occurs of mixing the slides up, which will make it run very poor.
dont run the quad with one carb rejeted and the other not, just do one at a time, know what i mean?
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
