Re-Jeting Rubicon questions
Texmud has re-jetted his, but what did everyone do? My rubicon is just a tad rich on idle as hot starts result in it slowly fireing and coming up to idle and if i stop quick it sometimes dies, I was thinking on either dropping the needle or one size smaller pilot....my altitude is 1000 feet and i ride in all temps from 20 to 100 deg's what does everyone think?
joe
joe
My forman does the same thing. What I do is give it a little gas when you start it up agian when hot and it will fire up no probablem. OR you could turn the idle up since they idle extreemly low. I notice when it is hot and your going slow and luging it in the ruff stuff sometime it dies out cause it idles so low. You could also rejet the slow jet circuit but don't touch the needle cause that for 1/2 3/4 and it will lean it out to much. The easyest thing to do is to bump up the idle a bit.
