Wheel Rings??
Old Jun 6, 2001 | 02:17 PM
LBZfreestyler's Avatar
hey guys. im about to purchase some .190 douglas rims, and i have a few questions about buying wheel rings. first off, when you add them to your rim, do you put them on the inside and outside of the rim, or just the outside? also, do you need them in front? i see some racers that only have them on the rear. and finally where the cheapest place to buy them from? thanks
Old Jun 6, 2001 | 05:30 PM
brokemybanshee's Avatar
You'd be better off buying the ones with the rings already attached.
Old Jun 7, 2001 | 08:26 PM
DSBUDDY's Avatar
take a look at some bead lock rims they r really strong too and they make for some really easy tire mounting
Old Jun 7, 2001 | 08:51 PM
if i had the money i would buy the beadlocks. there so dam expensive though. i think what i will end up doing is buying the race wheels outa denis kirk. i think them are the cheapest. the .190 ITP/Douglas rims will be okay in the front right? im kinda on a tight budget but i want something that will last me. i don't race but i ride it like i do. i seen some race quads with just the race wheels in the rear. well thanks anyways.
Old Jun 7, 2001 | 11:00 PM
You might want to check out rockymountainatv, they are usually cheaper, if you do get the wheels with the re-enforcement rings you want them on the FRONT before the rear, .190's should be fine, I'd get regular ones for the rear and enforced ones for the front if you have the $$$.
Old Jun 8, 2001 | 02:14 AM
DSjockey's Avatar
Might want to check out these folks too I've heard they might be cheaper than Rockey Mtn. ATV Wind Mountain ATV
meddy0388
Sep 9, 2015 06:41 AM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
