Mojave air filter?
Old Jun 7, 2001 | 01:34 AM
1BEARMAN's Avatar
Does anyone know the k&n air filter number that clamps directly to the back of the carburetor?Also how is it working for you.
Bearman
Old Jun 7, 2001 | 09:36 AM
mojaveaddict's Avatar
I dont remember the number but this will get it done for you. Remove the rubber tube from the carb and measure the carb across the flange from outside to outside. I think I remember it being 2 1/16 or 2 1/8 inches or somewhere close. Anyway get the right measurement and then go to http://www.knpowersports.com/docs/ap...rsal_apps.html
Look for the filters that have the flange ID (first # in the chart) that fit your measurement. Pick out the one you want. It needs to have an angle flange of 5 or 10 degrees to help clear the seat bracket. I run the 3 1/2 x 4 size but the 5 inch length may fit. I think the 6 inch ones are to long to fit. Take the part # from the chart to a k&n dealer. Be sure to get an outerwear for the filter. I would suggest one of the water resistant outerwears since you are loosing the snorkle.
Old Jun 7, 2001 | 07:44 PM
JD250R's Avatar
This might help, but it might not. What I did was get a K&N pod for a Banshee with 34mm carbs.
Old Jun 8, 2001 | 12:11 AM
ltracerx's Avatar
Don't get a K&N get a Uni-Filter. I did this and it works awesome. Just clean it monthly or when it get really dirty. My Mojave gained alot of low-end and also ran much better. I had to make a rubber boot to fit it but that was because it was for my old 230, but just go down to a shop, not dealership, and ask them what size Uni pod will fit on your carb
Old Jun 8, 2001 | 01:31 AM
1BEARMAN's Avatar
Thanks everyone for the help.I will use youre suggestions this weekend.
Bearman
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
