scrambler noise
Old Jun 10, 2001 | 11:12 PM
putter's Avatar
I have a 2001 Scrambler 2x4 and there is a grinding like noise coming from somewhere in the rear,I think. It doesn't do it all the time but most of the time. I think it is the chain but I'm not for sure. Has anybody else had this problem. It's loud and annoying and a little embarrassing at times,but I can deal with that.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jun 10, 2001 | 11:16 PM
OffRder15's Avatar
Is it like a clunk every now and then? If it clunks, it's your chain for sure.
Old Jun 10, 2001 | 11:56 PM
polarisrules44's Avatar
Its probally your chain ..First check the front sproket to see if a tooth has been chiped.Also try oiling your chain with chain wax you can get it at your local dealer.Also see if your chain is loose.You should only be able to move it about 1 and a half inches up ...hope this helps
Old Jun 11, 2001 | 12:35 AM
codeman's Avatar
I had a very annoying rattle at the rear of my Scrambler. I found it to be the lower part of the air box vibrating and hitting a brace right behind it. I wire tied a peice of pipe insulation around it and the noise disappeared I don't know if this could be your problem but its worth checking it drove me nuts till I found it.
Old Jun 11, 2001 | 05:50 PM
putter's Avatar
Thanks for the info. I will give the chain and cog a closer look.[img]i/expressions/face-icon-small-happy.gif[/img]
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
Matt123
Sep 29, 2015 01:29 AM
Ahtatu
Sep 28, 2015 12:14 PM
