What is the best synthetic motor oil?
Old Jun 11, 2001 | 11:41 AM
PrairieDust's Avatar
Just finished breaking in my KVF650 and want to switch to synthetic.
What weight and brand is the best for this machine?
Old Jun 12, 2001 | 09:51 AM
mordr's Avatar
If your clutch uses the same oil as your motor as in my Mojave, you should not use synthetic as it will cause your clutch to slip. Just use regular oil.
Old Jun 12, 2001 | 01:14 PM
Actually there is nothing inside but gears because the belt system acts as the clutch.
Old Jun 12, 2001 | 04:12 PM
mordr's Avatar
I answered before I thought-sorry for the useless reply. Any synthetic that meets the API standards your manual calls for would be good.
Old Jun 13, 2001 | 09:26 AM
MudMonger's Avatar
I would get a synthetic or blend that's designed for motorcycles. They are formulated differently than the regular automotive type. For one thing, they don't contain friction modifiers, so they won't make a wet clutch system slip (although that doesn't pertain to you're situation I thought I would clarify that "clutch slip" deal) And they contain additives which protect the metal better, but aren't safe for catayltic converters, so automotive synthetics ain't got um. Mobil1 even makes one for V-twin bikes, but any synth will likely be just as good.
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
