Big Blaster problems....HELP
I was riding my Blaster today and on my way home it stalled out and came to a stop. As if it where out of gas. It sputtered and poped a little and stopd. I turned it on reserve and tried to kick it and the kickstarter wouldnt move at all. Did the piston seeze??It is a fairly new piston and sleeve put in around new years.
Guest
Posts: n/a
You didn't happen to run out of 2-stroke oil did you. I know that will usualy cause the piston to lock up, but if you are lucky it won't. when I did that I just ended with a slight case of piston slap that is gradualy getting worse.
2000 yamaha blaster
1986 suzuki quad sport
2000 yamaha blaster
Ok I tried pushing it in sixth gear and it did move and I could hear the piston going up and down. And now the kick starter moves.Oh and I rpe mix my gas so I know it isnt an oil problem. But the thing still wont start. At least it isnt cooked though.
I think u should buy a block off kit for the oil injection and mix gas instead. I had a 2000 blaster.I personaly dont trust the injection system my causins oil system stoped working one day and he fried it.
The only way to really know if your blew a ring or the like would be a compression test.
Just because the piston moves does not mean you are in the clear just yet.
Check it over good.... Kicking a machine with a bad ring can damage the cylinder really bad.
