Big Blaster problems....HELP
Old Jun 15, 2001 | 04:06 PM
RdingManiac420's Avatar
Ok the jetting is right on and the plug looks really good but I will try to put a new one in. Oh does anyone happend to know what the compresion is suppost to be so I can do a test?/ thanks.
Old Jun 15, 2001 | 05:26 PM
Does anyone know what the compression should be?? Or would it be differant since I have a weisco piston, rings and a sleeve?? So can anyone tell me at least a close estimate of the compression? thanks.
Old Jun 15, 2001 | 05:36 PM
sAyIt_fmf's Avatar
Anything below about 90-95 is in need of a rebuild. 115-120 should be about right for a stock bike. Well at least that is what the banshee calls for.
Actually...I don't even think you will be able to get it started below 90.
Old Jun 15, 2001 | 06:37 PM
Ok well I seem to be getting around 25psi so I would say I am in need of some engine work. Thanks for everybodies help!
Old Jun 15, 2001 | 08:19 PM
  #15
mt400EX's Avatar
What is meant by blowing the top end?
Old Jun 16, 2001 | 12:03 AM
  #16
ProCrctBlaster's Avatar
this happened to my freind to one of my freinds with a blaster,take your park plug out and look and see if it has little metal ***** than you piston might be chiped take your cylinder off and look.
Old Jun 30, 2001 | 02:30 AM
  #17
jts's Avatar
jts
you're screwed !!! Mine did the same thing. My oil pump quit pumping and the piston melted and got chewed up bad.
Old Jun 30, 2001 | 06:01 PM
  #18
dirt817's Avatar
mt400ex- "blowing the top end" is a way of saying its time for a rebuild. s stroke need a new top end about every 300-400 hours depending on use. 4 strokes can get away with alot more hours. When you blow the top end, it means the piston/rings are no longer usable and need to be replaced. You will know when it happens. What happened to 420 happens alot.
Old Jul 1, 2001 | 07:34 PM
  #19
H300F's Avatar
get it bored, new piston, new gaskets, and your set.
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
