86 250R check oil bolt
Old Jun 15, 2001 | 07:59 PM
boxcars4's Avatar
Have a little problem... You know that bolt on the clutch side that is the check oil bolt? well when I put the engine back toghter I was filling it up with oil and had the bolt out. I put it back in and it broke the head off... Well it looks like it oil is slowly I mean slowly coming out. Like maybe a couple drops a day. Anywyas I really don't want to take the case off again until I need to next month. So I was thinking of using RTV or silcone to seal it for the time being? Then when I take the case off I can back the bolt out and replace? what you guys think? also how much oil is suppose to be in there? Seing I can't tell now?
thanks
Old Jun 16, 2001 | 10:35 AM
evhwg's Avatar
i believe in the saying fix it right or pay later.
the part would cost you a whole $2.00's and an hours time. is it worth chancing having that bolt vibrate into the clutch cover and causing a major mess? do it right you'll feel and sleep better for it.
Old Jun 16, 2001 | 11:04 AM
Backcountry's Avatar
evhwg said it pretty well, there is a huge chance that it will vibrate in and then be sent thru all the turnings of the tranny and clutch systems. $$$$$
Have you tried to get the bolt out using a pointy screwdriver, scribe, awl, or similar object. Try to get the broken off portion to turn in the hole and come out. If you remove the clutch cover, then there may be enough protruding on the opposite side to grab and thread all the way thru the hole.
Dustinyoungs
Jul 24, 2015 07:18 AM
CRamshaw777
Jul 18, 2015 05:46 PM
skeets44
Jul 17, 2015 01:04 PM
Unzzy66
Jul 11, 2015 10:01 PM
Shifts
Jul 3, 2015 07:59 AM
