Banshee stutter just before power band?
I have a 99 banshee all stock except for FMF silencers, and a Whit Bros. Boost Bottle. The past 2 times out ridding it seems to stutter just before the power band. I tried a different set of plugs, with no change. It acts like it has taken on some water almost. I am thinking possibly the carbs need adjusted. Any thoughts, advice, or help is apprieciated.
Chances are its running funny because of the heat outside, I dunno about in NY but here in Maine its been scorching for the last couple days, when its hot out your machine might run rich (my blaster has been), which would explain the stutter, do a plug chop, if its rich move the jet-needle up a notch, make sure you do a plug chop if you change it. good luck.
Logan Collins
Sep 5, 2015 08:03 PM
