HELP!!! Clutch making clicking noise!!
Old Jun 18, 2001 | 11:15 AM
trailblazer00's Avatar
[img]i/expressions/face-icon-small-mad.gif[/img] Ever time I go down a hill when the clutch tries to hold back it makes a hell of a clicking sound. I thought it waz the helix but I put in a FTR clutch kit and it still does it. IF I stay on the gas, or the bike freewheels it doesn't do it. I took it to the polaris shop to have them put it in and he said my clutch bottons were pretty wore and that I should chage em. We just changed them not to long ago. Could this be whats making the clicking noise. I will probebly replace them with HPD's.
Sorry for long post but please help!!!
Thanks Ryan H.
Old Jun 19, 2001 | 01:07 PM
Farmr123's Avatar
Yup, loose buttons in the front clutch sure can cause the clicking. I have seen them so loose you can hear a rattle when idling (not a good situation).
Old Jun 19, 2001 | 03:31 PM
Farmr,
Are you sure you didnt mean the back clutch buttons? I didn't know the front had any.
Thanks Ryan H.
Old Jun 20, 2001 | 09:41 AM
Farmr123's Avatar
I mean the front buttons. They usually will outlast the rear by quite a bit. I think one reason they get loose is a lot of people aren't even aware they are in there. If you look carefully between the towers and spider of the front clutch, you will find 6 buttons, maybe about the size of a dime or so (but hopefully thicker). These can work loose eventually and if they do, it can cause the front clutch to click or rattle during idle and de-acceleration. It usually doesn't rattle under load (unless it is REAL bad) because the power of the engine will put enough load on it to take up any slack.
I'm not saying not to look at the rear, just to check the front while you have the belt cover off. They are only a couple bucks apiece, but are hard to get to (need a clutch buster or 'grunt' tool). I hear that HPD has come out with heavy-duty buttons that are SUPPOSED to be indestructable, but cost about 4 times as much as the Polaris ones.
Old Jun 20, 2001 | 09:44 AM
Farmr123's Avatar
I should add that to see if they are loose, you grab one half of the front pulley in each hand, and try to wiggle them against each other. You shouldn't be able to get them to wiggle at all.
JoAnnS
Jul 23, 2015 02:18 PM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
D-Hagz
Jul 4, 2015 02:19 AM
