torque specs
Old Jan 6, 2000 | 10:15 AM
91_350's Avatar
I have 3 questions here, When Retorquing the cluth onto the crankshaft, what is it suppose to be toqued down to? When Retorquing the Jug onto the base what is that suppose to be torqued down to? Also what about the head? this is a 2 stroke for those of you who are wondering
Thanks
John
Old Jan 6, 2000 | 10:03 PM
rooster's Avatar
Cylinder: 25-29 ft.-lb.
Head: 17-18 ft.-lb.
I would assume the clutch your talking about is the primary clutch, since it sounds like you're rebuilding the engine. I would assume the clutch cover torques will be useful also since both the inner and outer have to be off to remove the engine.
Drive pulley screw: 40 ft.-lbs.
Driven pulley screw: 17 ft.-lbs.
Inner cover screws: 12 ft.-lbs.
Outer cover screws: 7.5 ft.-lbs.
dannytas
Sep 26, 2017 06:31 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
raman8tor
Sep 20, 2015 07:35 AM
