42mm carb for trailblazer
Old Jan 9, 2000 | 10:44 PM
trailblazer00's Avatar
Will a 42mm carb fir and work on a trailblazer if not whats the biggest size for it?
Old Jan 10, 2000 | 01:10 AM
talonhawk's Avatar
Trailblazer00,
I've got a 38mm tmx Mikuni on my 99 TB.
It came with an adapter that connects from the carb to the intake port. I did have problems adjusting the throttle and oil pump cables!! My air box has been totally removed and replaced with the K&N filtercharger.
I don't know about the 42mm carb. Hotseat has the 38mm carb for the Trailblazer which in MY opinion works pretty good BUT is not worth the cost to install it.
JIM 99TB with Hotseat/HPD mods
Old Jan 10, 2000 | 04:11 PM
How do you remove the airbox? I have a k&n filtercharger but wehat else do u need?
Old Jan 10, 2000 | 08:12 PM
talonhawk's Avatar
Trailblazer00,
To remove the airbox just remove the two screws at the back, loosen the clamp that holds the airbox to the carb and pull it up and straight back. Then clamp your K&N filtercharger, part # RU-1760 to the carb.
Old Jan 10, 2000 | 08:51 PM
talonhawk, all I have is the filter charger it just fits down into the airbox dont I need somthing else to hook the filter to the carb.?
Old Jan 11, 2000 | 12:21 AM
talonhawk's Avatar
Trailblazer00,
Is your filtercharger a (RU-1760)?
If its just the drop-in kind there is nothing on it to attach it to the carb! The RU-1760 filtercharger comes with a rubber bootie already attached to it. That rubber boot is what attaches to the carb. Also I don't know if the RU-1760 will fit on a 42mm carb. It could have a different size intake which would make for an extremely tight fit for the filtercharger to go over.
Old Jan 11, 2000 | 05:50 PM
Ya, but will a 42mm carb work because the 38mm and 42mm are about the same price.
Old Jan 11, 2000 | 08:34 PM
talonhawk's Avatar
Trailblazer00,
I have a Mikuni catalog that says a 38mm carb will work on a 250 or bigger engine.
The TMX carb gave my already modified TB a good boost but it does use more gas and I only put 92 octane or better in it. The 42mm will PROBABLY work. BUT work alot better on a bored and stroked engine and not just one with bolt-on mods.
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
shewshew989
Jul 14, 2015 03:09 AM
shewshew989
Jul 14, 2015 02:54 AM
