trail blazer problems,need help please
Old Jul 10, 2001 | 04:16 PM
madman223's Avatar
before this past winter i put a 140 main jet in it,& it ran great,so i put the 130 back in,for the summer,but now everytime i touch the throttle it just dies,it completly bogs down i tried adjusting the carb but no matter what i did it stayed the same ,so when i went to check the main jet today it fell out so i put it back in making sure it was tight ,but its still doing the same thing can someone please help me.
thanks,
Old Jul 10, 2001 | 11:25 PM
x_scrambler3's Avatar
Did you try puting the 140 back in an seeing if it still dose it? Have you adjusted the needle in it.
Old Jul 11, 2001 | 04:09 PM
madman223's Avatar
i tried the 140 again but same result.i didnt mess with the pilot,that i know of,all i did was take the bolt out & unscrewed the main that was it.thanks for replying ,its my wifes bike & shes not happy!!!
Old Jul 11, 2001 | 09:19 PM
Balzak's Avatar
Move the clip on the needle of the carb, that should take care of it.
Balzak
2000 scrambler 400 2x4
can you say HPD?
Old Jul 12, 2001 | 01:16 PM
madman223's Avatar
thanks everyone for replying,i messed around with it yesterday,i noticed when it was in neutral i could rev it up but as soon as i put it in gear,& try to throttle it it bogs down,even when i try to give it a little bit of throttle it bogs down,it acts like its losing all power, thanks
Old Jul 12, 2001 | 05:28 PM
RideRed04's Avatar
check your breaks, and all the drive system for obstructions.
Old Jul 12, 2001 | 10:05 PM
It sounds like it is the reverse limiter box has gone bad. You can disconnect it an see if that fixes it. Mine went bad in my 95tb an iwould not let it pick up rpms so that is what I would check
Old Jul 13, 2001 | 04:21 PM
madman223's Avatar
x_scrambler ,how do i disconect it because i noticed when i pushed the reverse limiter button i didnt go no faster & it would bog down when i pushed it .thanks everyone for your help.i have another question is there any way it could be the top end needing rebuilt ,this thing only has 25hrs on it,maybe a little more but not much.it sits most of the time .she only rode it a few times ,& i took it out a couple of times to play in the mud.how hard is it to put a cluth kit in ,& do you need special tools.
Old Jul 13, 2001 | 06:23 PM
I had 5 years on my Tb before the first rebuild. Under the front nose piece there is a black slinder box with about 5 or 6 wires running to it.at least that is what mine looked like.There is a green wire a white wire I can't remeber the other colors of wires but I disconnected the white wire. If you disconnect the limiter box you are also disabling the the safty for the throughtle sicking .Each wire that comes out is sapprat for the other so can disconnct one then try an see if it helps you.
Frisky2050
Apr 9, 2020 11:19 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
