to anybody planning on splitting the crakcase on their banshee...
Old Jul 18, 2001 | 09:18 PM
warrior3443's Avatar
i heard the other day just before opening the crankcase on jiz's banshee that not to do it yourself. a buddy of mine said that the two halves are pressed onto the crankshaft. he said he did it on his bike and it about shook him off the bike because he didnt kno and took his case apart and then put it back together without pressing the case onto the crank shaft. so if u gotta get into the bottom end i would recommend taking the bottom half to the dealer or somebody who can put it back together properly. not sure if u knew that but hey!, it may save somebody from making that mistake. see ya
Old Jul 19, 2001 | 07:32 AM
b370's Avatar
Warrior:
That is completely untrue..... I have split many banshee cases and never once had to "press" the cases on or off the crank assy. The reason a bike will "shake" like that is because something is not balanced... If the crank was rebuilt in that motor and wasnt trued.... then thats where your vibration can start from.
Splitting the cases on a banshee is not that hard.... Get yourself a Clymers or factory repair manual and the right tools..... take your time, and if you have any questions post them here and I am sure one of us could walk you through it.... I have 2 banshee lower ends apart on my bench right now..... I can take digital pictures if need be......
good luck
Old Jul 19, 2001 | 08:05 AM
chriscoll1's Avatar
I have split a Shee case a couple times.Nothing's easier!! Pull the top off and everything sits in the bottom end. The only thing I didn't like was there was no gasket,you have to Yamabond them together.
Old Jul 19, 2001 | 10:19 AM
garyc660R's Avatar
B370....which side is better to lay the crankcase on to get it apart without everything falling out? Never had one apart, but possibly will someday since my bro has one.
badgerboy1
Sep 26, 2017 06:11 PM
bigred20653
Oct 2, 2015 10:05 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
1ArmBandit
Sep 8, 2015 08:59 PM
