SPORTSMAN SHIFTER
Old Jan 22, 2000 | 05:28 PM
mac1181369's Avatar
Ok, I have figured it out (after people have told me) that my shifter bar, or whatever it's called, needs to be adjusted. I looked and there are two, one going from shifter to front of transmission, and another goign from shifter to back of tranny. The problem is, it only goes from neutral into low. When you shift, only the shorter bar moves. Can anyone tell me how to adjust this to fix it back. Like specifically which one to shorten or extend?
Old Jan 22, 2000 | 07:06 PM
SWAC's Avatar
I just went through a readjustment. You will have to play with both rods to find the happy medium for the shifter. I found that with a little fiddling, you will again be able to follow the H,N,L,N,R pattern properly. Make sure all gears will go in with a CLUNK. Make sure your idle is low enough so that your not hearing any gear grinding.
Njrider1230
Jul 29, 2023 05:16 AM
STLyamwar
Jul 25, 2020 04:44 AM
superdizzyboi
ATC 3-Wheelers
Aug 30, 2015 07:22 PM
frostphase
Aug 19, 2015 07:11 PM
Schneider
Jul 24, 2015 05:05 PM
