SPORTSMAN SHIFTER
Ok, I have figured it out (after people have told me) that my shifter bar, or whatever it's called, needs to be adjusted. I looked and there are two, one going from shifter to front of transmission, and another goign from shifter to back of tranny. The problem is, it only goes from neutral into low. When you shift, only the shorter bar moves. Can anyone tell me how to adjust this to fix it back. Like specifically which one to shorten or extend?
I just went through a readjustment. You will have to play with both rods to find the happy medium for the shifter. I found that with a little fiddling, you will again be able to follow the H,N,L,N,R pattern properly. Make sure all gears will go in with a CLUNK. Make sure your idle is low enough so that your not hearing any gear grinding.
Njrider1230
07-29-2023 05:16 AM
