Chain Roller
Old Jul 19, 2001 | 12:43 PM
eli54's Avatar
Who has a decent roller to replace the stock unit?
I've lowered my DS for flat track, and it ate up a Moose Racing heavy duty roller in no time.
Elliott
Old Jul 19, 2001 | 11:25 PM
NewDSLover's Avatar
I bought the TM Designworks Roller Bearing. It was around $35 bucks before shipping.
TM Designworks located in Phoenix, Oregon.
Phone (541) 535-1612
Old Jul 19, 2001 | 11:29 PM
btodd's Avatar
I also recommend the TM. I have a TM Design chain roller and chain slider on my LT500 and they are very high quality.
Old Jul 20, 2001 | 09:36 PM
CALDS650's Avatar
Elliott where due you race and how did you lower your DS?
Old Jul 21, 2001 | 11:49 AM
ProEMTPFF's Avatar
Elliott, I use a skateboard wheel and berings. I've had it on for a year now with VERY little wear. It works great try it. I went to a local skateboard shop and got a use wheel from them for free.
Chip
Old Jul 23, 2001 | 02:14 AM
BlackHawk's Avatar
My chain roller died a miserable death this weekend and I replaced it with a skateboard wheel. The guy at the skateboard shop was perplexed as to what I was doing, and when I told him I needed 4 bearings for it instead of two he was like "That wont make it roll any faster.." I told him it was for speed anyhow. Then he asked what I was using this for but I'm not sure it made any sense to him. He only charged me $5 for the 'blank' wheel, and gave me some used bearings for free. I wanted to get this cool clear-red wheel but they only wanted to sell them in sets of four - so I made due with a plain black one. Total cost OTD: $5.40 including tax. That is probably about what the TM Designworks model would cost in shipping alone.
Old Jul 23, 2001 | 01:15 PM
eli54's Avatar
I got a TM roller from Alba. Thanks for the help!
To race my DS on flat track, I took out the red spring on the rear shock. I had to cut down the spacer between the two springs so it was flat on one side to locate the top of the big spring. I set the ride height with the preload adjusters.
Up front, I installed Progressive Suspension 17.5 inch shocks, part number 13-1242B, and 85/170 springs, number 13-1333B. On the right (outside) shock, I replaced the short spring with a spacer to stiffen it up, and kept the left spring stock.
I still have the stock tires, with 3-4 lbs in the left side, 5 lbs right front, 6 lbs left rear.
The track is Competition Park in San Jacinto, CA, a 1/4 mile oval with long straights and tight corners, loose decomposed granite surface. I wouldn't want to try the stock tires on a blue groove. Track is open for practice Wednesday Nights. Next race is August 18, call 858-277-1591 for more info.
Old Jul 25, 2001 | 09:50 PM
Air's Avatar
Air
Chain rollers and slides These guys are great and have them in red, yellow and black
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
