Jet kit and air filter
Old Jul 19, 2001 | 11:15 PM
Juice's Avatar
I just purchased a 2002 wolverine and was looking to put a K&N air filter on it. I saw an add that also talked about a jet kit. Does that work with the airfilter, if so what does it do? I saw that it gave it a little more power and it was cheap so I thought I might do it. Also is it a good idea to put a prefilter on or will it restrict too much air? Thanks for clueing me in.
Old Jul 19, 2001 | 11:50 PM
ridnwarrior's Avatar
A jet kit is for your carb. It gives you a new needle that you can make different settings with and it gives you a bunch of jets for the carb. If you put the K&N filter on, a prefilter is worth it because it won't block any air just particles of dirt from getting in. I think the prefilter is worth it. Now if you let in more air with the airfilter and you let more gas in with the jet kit you should let more exhaust out by changing the silencer on your exhaust.
Old Jul 19, 2001 | 11:53 PM
Juice's Avatar
How would I change the silencer on my exhaust? Would that require new pipes? That will probably make it louder though?
Old Jul 20, 2001 | 12:00 AM
Juice's Avatar
As I'm looking around it looks as if K&N sells the jet kits with their filters. Could I put a uni filter with K&N jet kits? I didnt see any uni jet kits.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
