does anyone make a case saver for a banshee???
Old Jul 20, 2001 | 09:11 PM
jiz's Avatar
jiz
I'VE LOOKED EVERYWHERE FOR ONE BUT I CAN'T FIND ONE ANYWHERE. I WATCHED MY FRIENDS WARRIOR CASE GET SPLIT OPEN WHEN HIS CHAIN BROKE CUZ HE DIDN'T HAVE A CASE SAVER AND I DON'T WANT THAT TO HAPPEN TO MINE. DOES ANYBODY KNOW WHERE I COULD FIND ONE AND AROUND HOW MUCH WOULD ONE BE?
Old Jul 20, 2001 | 11:15 PM
ridnwarrior's Avatar
No idea where you can find a case saver for the Banshee. I own a Warrior though and I'm interested in hearing more about your friends Warrior. What year was the quad and how did he fix it after it happened? Did he have to buy 2 new case halves or 1? does he have a case saver now? Let us know. Thanks.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 21, 2001 | 01:31 AM
Zorro's Avatar
I had that happen to my shee. The chain wasn't closed perfectly (the clip wasn't in its groove), and the chain slammed the case. It's broken, right above the sprocket...but it was a just a piece of aluminium...it acted like a case saver (in this case, more like a carb saver). It broke 6 months ago, and I left it this way (no hole in the case)...I just have one chance. I should reweld it, but I would need to take everything out...so it'll be for this winter!!
It sucks, caus now, if the chain breaks...I loose the left carb...ouch
Old Jul 21, 2001 | 02:32 AM
oppi's Avatar
I believe Alba now sells a case saver for the banshee. It cost like $70. Other then them i dont believe there is any.
Old Jul 21, 2001 | 06:56 AM
CALDS650's Avatar
<< I'VE LOOKED EVERYWHERE FOR ONE BUT I CAN'T FIND ONE ANYWHERE. I WATCHED MY FRIENDS WARRIOR CASE GET SPLIT OPEN WHEN HIS CHAIN BROKE CUZ HE DIDN'T HAVE A CASE SAVER AND I DON'T WANT THAT TO HAPPEN TO MINE. DOES ANYBODY KNOW WHERE I COULD FIND ONE AND AROUND HOW MUCH WOULD ONE BE? >>
James Lucky has one http://www.jlatvproducts.com/
Old Jul 22, 2001 | 05:27 PM
jiz's Avatar
jiz
HIS WARRIOR WAS AN OLD CLUNKER. IT WAS THE FIRST YEAR THEY MADE THE WARRIOR AND IT LOOKED AWFUL. IT PUT A LITTLE HOLE IN HIS CRANKCASE BUT HE JUST WENT THE CHEEP WAY AND PUT SOME JB WELD ON IT AND IT'S WORKED FINE EVER SINCE.
Old Jul 23, 2001 | 10:22 PM
Holyman's Avatar
There's a guy that lists one made of Nylon or some other industrial plastic on eBay every once in a while. His opening bid is usually around $40. It looks pretty well made too.
Old Jul 23, 2001 | 11:18 PM
H300F's Avatar
zorro., it happens to almost everyone that has a banshe what has happened to you. happened to me. i just cut the piece that broke off with my dremel. every banshee my friends have is already cut cause their chain flew off. i wouldnt even spend the time to weld it all back together unless your nuts.
Old Jul 24, 2001 | 01:10 AM
Zorro's Avatar
I'm not nuts, but I might as well reweld it...this winter, I will change my top end, and check in the same time rod/crank bearings seals. Since my dad has a mig welder, I can do everything myself...
Cole Hadden
Jun 15, 2025 09:05 AM
SDR-II
Sep 29, 2015 01:06 AM
ghost civic
Jul 19, 2015 10:13 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
