Blaster flywheel removal
Old Jul 21, 2001 | 07:48 PM
ReadyShootAim's Avatar
How? I've got the nut and washer removed, but the flywheel will not budge. Is the flywheel pressed on the shaft? Does it require a special tool? If so, does anyone know the approx cost?
Old Jul 21, 2001 | 08:21 PM
92LT's Avatar
It requires a special tool. It is fairly simple and costs about $15-25, depending on where you get it. A good shop should have one in stock because it fits several other vehicles besides the blaster, or catalog. Don't try to pry the flywheel off because you can bend the crank and cause major damage.
Old Jul 21, 2001 | 11:45 PM
ridnwarrior's Avatar
Order the puller from Rocky Mountain ATV or Dennis Kirk. That should be the cheapest way. If you need it again you'll have it.
chingchangchong
Aug 7, 2022 11:36 AM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
