chain poblems,I need help!
Old Jul 22, 2001 | 02:54 AM
polarisrules44's Avatar
i have a 2000 t-boss and as i take off it allmost sounds like my chain is poping off the spocket and then going back on it..it does this off the start,, and when i am travling at mid or high speeds it just clicks.i checked the sprocket and all the teeth seem to be there ..if anyone can help me out or just give me an idea i would be very greatful..thanks:mike
Old Jul 22, 2001 | 02:57 AM
xploridaho's Avatar
I had the same problem with my 98 xplorer. I finally got a friend to ride it while I rode beside and watched the chain in question. Turns out the chain was bad and a couple of the links were binding up and wouldnt straighten out. I replaced the chain and no more problems.
Old Jul 22, 2001 | 03:29 AM
OffRder15's Avatar
I had the same problem. Turns out the rollers were damaged on two links. The chain was 2 years old anyway, so after a new chain, ITS ALL GOOD BRO! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 22, 2001 | 02:09 PM
thanks for the replies guys ..and also how much does a new chain cost.could this be because my chain is loose .i checked my chain and it seems to be loose ..just thought i'd ask.thanks:mike
Old Jul 23, 2001 | 01:49 AM
2002GRIZZ's Avatar
Like offrdr15 how he said he had some bad links. I had 4 broken rollers after 3 months of use. this was al lmy fault. I had tightened my chain up to tight. This can also happen if you have it to loose. So if your chain has been tightened lately or is really loose the rollers are broken. And if you put it up on a jack and move the wheels with your hand you can see where the rollers are broken.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
