Low smoke two stroke?
Old Jan 25, 2000 | 11:37 AM
Thor's Avatar
I have tried the Polaris standard two stroke oil and Phillips 66 Injex in my Sportsman 400 with satisfactory results. But, I am looking for an oil that smokes less with less odor, does anybody have any suggestions?
I recently tried the Quaker State Itasca Synthetic oil but found that it smokes more than the other two mentioned. What has worked for you?
Sportsman 400 "... it smells like victory!"
Old Jan 25, 2000 | 11:49 AM
JOEMAG500's Avatar
Have you tried the Polaris synthetic 2-stroke gold? I have little or no smoke from my 400 explorer when I use it. It's a bit on the pricey side, $26.99 a gallon but mine doesn't use much and it's what they recommended at the dealer.
Old Jan 25, 2000 | 12:16 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Tror
Be careful running cheap oils! I have been working on outboard motors for years and that normally is a contributing factor when two-stroke outboards fail-cheap mixing oil. Polaris Gold works for me.
Old Jan 25, 2000 | 12:43 PM
Thor's Avatar
No I haven't tried the Polaris Gold yet.
Weedy, do you remember what oils were used when the outboards failed?
I hear a lot of talk about AMSOIL but am not familiar with it.
Old Jan 25, 2000 | 01:51 PM
Hawkman's Avatar
Definitley, go with the gold. My SC400 loves it. Very little smoke.
Hawk - stock (for now) 99 Scrambler 400
Old Jan 25, 2000 | 02:00 PM
codeman's Avatar
I also use synthetic gold and have very little smoke.From the way the dealer explained there is a difference in synthetics and regular oil as far as how the injector is set,be careful.This is my first two stroke so I don't completely understand the whole oil injection set up.
Old Jan 25, 2000 | 03:17 PM
SportKod's Avatar
I use the Polaris Gold also, smokes only a little bit while warming up. After the bike warms up, It only gives a very little puff of smoke once in a while, bike isn't running lean either.
SportKod
99 Polaris Sport
00 Yamaha Kodiak
Old Jan 25, 2000 | 05:53 PM
Thor's Avatar
Does the Polaris Gold have a mild odor?
Old Jan 25, 2000 | 07:32 PM
Mayhem's Avatar
I am about to buy a new Scrambler 400. My question is, is it safe or recommended to run synthetic oil during the break-in period? I know that for 4 stroke engines you aren't supposed to run synthetic in them at first, so that they can wear a little at first to get all of the parts "acquainted" with each other. Does this hold true with 2 strokes at all?
Thanks guys!
Old Jan 25, 2000 | 07:41 PM
SportKod's Avatar
When you buy your new Polaris, it comes filled with regular oil, plus, the tank of gas it comes with is pre-mixed with oil so everything gets nice and lubed up from the start. You can start adding the synthetics after a tank or two of gas.
