GRINDING NOISE ON BLASTER FRONT BRAKES WHEN WET...HHHEEELLLPPPPP!
My blasters front brakes make a loud grinding/honking noise when wet (and for a long while after they are wet, even up to weeks! does anyonbe know what is wrong with it and how to fix it??? thanx in advance 4 all of ur help!!! cya
You can replace the stock pads with DP Pads ( i had good luck with them ) for around 40 bucks total. You can however replace the fronts with hydro discs, im not aware of any aftermarket kit, all the ones ive seen were custom jobs with banshee or warrior spindles.
This happens to me all the time. Sometimes it makes that loud noise and then locks up. The pads are fine but there where little chunks of rust and debris in the drum. Just take it apart clean it real good and even use some high grip sand paper and clean rust off of the drum.
Frisky2050
Apr 9, 2020 11:19 AM
joeyupton
Jul 14, 2015 11:51 AM
