hrc cam
Old Jul 24, 2001 | 06:20 PM
jp400's Avatar
i was wondering what the differince is between the hrc,gt thunder,white bros. is hrc good,bad or indiferent to others.and where can i get one????
Old Jul 24, 2001 | 10:29 PM
250rampage's Avatar
The HRC cam is a cam made by honda, designed for the XR400r. The reasons I went with the HRC was that it was a drop in cam (no hardfacing, or extra work needed), and that it was made by honda, so you know that there will be no complications. I do sugest though, that anytime you get a new cam, you get new valve-springs. It should be also noted, that the HRC cam is not the most agressive cam you can buy, but it does increase power significantly on top end, and offers a more even power spread than a full-race cam (this means a less fatiuging (sp?) ride, but not quite as much performace). It's all in whaat you want.
Also, I have heard from my engine builder that the Honda cam is more reliable than web, and some other manufactuer''s cams. Additionally, a more aggressive cam means less fuel economy.
