I need more power for the holeshot
Old Jul 25, 2001 | 06:47 PM
crazybob's Avatar
I have a 99 sport 400: i have been modifing it, wiseco piston kit bored over, k&n airfilter, springs shocks, dg pipe and silencer, and has been overhauled.
Alright now here's the problem, all my friends have dirtbikes and they are quick, my friend has a 99 cr 125 and it is completely stock. i raced him on a straitaway and we were side b side the whole way, what else can I consider doing to it to blow him away?
Old Jul 25, 2001 | 06:58 PM
articcatsux's Avatar
you could change your tire size smaller u would probly beat him of the line but then he would catch you also i would take off that dg and switch to hpd or hotseat they are suposed to be the best i know the dg pipe looks good but i heard they dont work good and are manly for dirt bikes and non automatics well that is what i think hope it helps
Old Jul 26, 2001 | 12:17 AM
JoshCVBz's Avatar
I don't know...it will take a lot to beat a CR125 (on top end) if it is in good shape and the guy can ride it (even though it doesn't take much skill to hold it wide open in 6th gear).
You should need more than just a pipe to do it.
Just figure it this way....once you can beat a stock Banshee up on top end then you'll have a better chance in beating a 125 since they are very close to a Banshee up top.
I'm not saying it's impossible...It would probably only take porting...Oh and don't forget your clutch kit.
Good luck with hopping it up!!!
-Josh
Old Jul 26, 2001 | 08:14 AM
HyperSport400XC's Avatar
crazybob,
"Speed is a question of money. How fast can you afford to go?" Anon.
Like articcatsux said, get yourself an HPD, RCR or Hot Seat pipe and clutch kit. Then add a set of reeds, porting, a high compression cylinder head and a larger carb. Lose some weight off your Sport, work on the suspension, and the brakes and you'll be set.
Old Jul 26, 2001 | 01:09 PM
AZ400L's Avatar
I think the general concensus on the DG pipes is that they are crap, although I do see a few guys with hi-perf machines using their silencer.
Go with either HPD or RCR. Start with a new pipe, carb and clutch components. From there some porting and headwork may be necessary. After those basics are done work on fine tuning your clutch and losing any dead weight from the machine.
Old Jul 28, 2001 | 11:04 PM
kkkiller300ex's Avatar
their is lots more things to do i would get parts frome hot seat preformance they make good aftermarket parts???
Old Jul 28, 2001 | 11:14 PM
bodineus's Avatar
FTR all the way......
MeadowlarkFarm
Nov 27, 2019 08:40 PM
bvolks
Sep 13, 2015 12:57 PM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
