Warrior Will only start with reverse?
Old Jul 26, 2001 | 01:35 AM
Blaster96's Avatar
Ok. I busted the warrior. While i was out breaking it in the starting curcuit realy switch got ripped off. I called up the stealership and told them to get me another. I got plugs and i hooked them up. (had to look at another 87 to get the wires right) IT would not start. After test after test everything checked out. Then just messing around it started this way.
Key on
Motor on
Press and hold the start button. (still nothing)
Pull the revers Lever back
NOw it turns over. PLease help me!
Old Jul 26, 2001 | 03:25 PM
ridnwarrior's Avatar
Sounds like a bad ground to the starter, starter switch or relay.
Old Aug 5, 2001 | 03:32 AM
Blaster96's Avatar
NO the starter has a good ground and also has a good starter silioniod. I ordeder the starter relay and i got a new style one. The new warriors have 4 wire to the relay switch and the old ones have three and a loop. Am i right here? I am getting used to starting it in reverse.
4xrider
Apr 10, 2017 01:36 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Nelson
Jun 20, 2015 01:59 PM
1000gade
May 27, 2015 12:37 PM
briancwatkins
May 7, 2000 12:34 AM
