Removing automatic decompression in Raptor
Old Jul 27, 2001 | 07:04 PM
NotuRaptor's Avatar
Had someone I highly respect tell me to perform this mod since the Raptor starts fine without it. The big reason to do it is to end some of the sudden stalls that happen in tight situations.
I am going to try it but I wondered if others have tried it or heard about it?
Old Jul 27, 2001 | 10:49 PM
Raptoryfn660r's Avatar
RIP Dear Friend
Is this an internal device or external? I can't see anything on the outside of the motor to disconnect. Seems like it would be hard on your starter motor,maybe not. I know on my 98 honda 4trax if the battery goes dead there is a lever to open the exhaust valves so its easier to start.
Old Jul 27, 2001 | 11:49 PM
Zorro's Avatar
I don't really get why it would prevent stalling...the decompressor is only activated when the starter is activated...
How does it prevent stalling (the f*cking 4 stroke reaction when you stomp the gas at near idle rpm...[img]i/expressions/face-icon-small-smile.gif[/img])
Old Jul 28, 2001 | 12:36 AM
deathtripper75's Avatar
The raptors auto decompresser is built into the cam, it is controlled by rpm (centrifical force),under 700 rpm there is a pin that protrudes from the cam and opens a valve, after 700 rpm that pin retracts and operates normally...as for the need for it that is a good question...i will look into that..
Old Jul 28, 2001 | 01:04 AM
RIP Dear Friend
Then it makes since that something would not quite be right if the rpms would go below 700rpm. Is that one reason why the raptors idle is set high?
Old Jul 28, 2001 | 01:21 AM
the raptor should be idled at 1,550rpm's
Old Jul 28, 2001 | 10:17 AM
NotuRaptor's Avatar
It makes sense then because I don't know about you guys but sometimes I drop well below 1,500 RPMs. This generally happens when landing off a jump/ledge at the top of a steep hill that requires an immediate slow down to turn. If you don't get the clutch pulled in quick enough, the engine RPMs drop quickly and you stall.
I am going to do the mod early week and test. If I like it, I will leave it changed; otherwise, I will put the pin back. Looking at the diagram in the service manual, this seems to be an easy mod. In any case I will post the results of my testing.
Old Jul 28, 2001 | 03:50 PM
leel2's Avatar
Hmmm,
Interesting, I went over the bars a few weeks ago when the engine stalled as I was going through some very technical rock crawling. Once it dies and you hit against the compression stroke without the engine firing, you stop dead instantly...
Lorrin
Old Jul 30, 2001 | 01:04 PM
ATVdunePro's Avatar
I would be really interested to see if this works, I have had very many situations when I have come on some steep drop offs or jumps when my RPMs were low and the bike would stall causing me to lurch forward.
I couldnt understand why it does this, and if there is a fix for this I would really like to know.
Old Jul 30, 2001 | 02:05 PM
kuz28's Avatar
Yes.i see the truth of it. count me in...
Good job NotuRaptor!!
As for the rest of you...get back to work! I need all the FREE mods i can get. do your homework and post.
AK
Firefighter400
Oct 8, 2022 06:38 PM
GNorm
Aug 1, 2015 11:06 AM
black_thunder
Jul 26, 2015 09:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
