Warrior Chain adjustment
Old Jul 28, 2001 | 07:47 PM
300exSTER's Avatar
My pal and i are getting a warrior running again. Its been sittin in the shed for the last 3 years. The only thing wrong with it is that it has a loose chain. Could anyone help me and tell me how to adjust the chain on a warrior. I belive its a 1994.
On any other fourwheeler, there are usally 2 bolts that you loosen up but i dont see 2 bolts on the swingarm. ANy help would be appreciated
ryan
Old Aug 5, 2001 | 03:25 AM
Blaster96's Avatar
on the hub there should be 2 long tube things. on each end there should be a bolt or nut head. loosen those and then at the bottom there should be 2 chain adjusters. Loosen those up and screw them in some. Be sure both sides are the same. IT is no problem. Some trail and error might also be used. _good luck_
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
manuelrivera
Aug 8, 2015 04:34 PM
Aug 6, 2015 05:29 PM
