NEED JETTING ADVICE WITH THESE MODS???
Old Jul 29, 2001 | 10:11 PM
VMAX12's Avatar
i just installed my pro design filter with the KN filter and outerwears
and i also cut the baffles out of the snorkle on my RAPTOR. when i tOok it for a ride
today i noticed a little low end bog. has anyone install these mods my exhuast
is stock. i need some jetting advice i know how to do it just don't want
to do it more than once. so what are the correct jets???
THANX
01 BLU 660R
Old Jul 29, 2001 | 11:22 PM
Joey9's Avatar
Since your running stock exhaust. I would say go up about 1 or 2 sizes on the main jets. Take the 145 main out of the right carb put it in the left one and get a 150 main for the right carb and see how it feels. You can also pull the baffle out of the stock exhaust for a little more flow. Kind of a pain without a torch but it can be done. Hope that helps
Old Jul 30, 2001 | 09:33 AM
pineman's Avatar
Raze the needles a notch.
Old Jul 30, 2001 | 11:42 AM
WyoDuner's Avatar
I agree with pineman, raise the needles a notch and see what that does for you. You MAY have to rejet but your bogging problem is needle or pilot jet/mixture related not main jet related.
By the way, I've noticed a lot of people having low end bogging problems when the remove the air baffle. Remember a big open free-flowing intake isn't exactly the hot ticket to low-end power. I think what causes the problem is there is less restriction going into the carb which means LESS VACUUM. Less vacuum means you are going to have a harder time drawing fuel out of the float bowl... That's just my analysis for what it's worth.
Old Jul 30, 2001 | 03:20 PM
VMAX12's Avatar
I CUT THE BAFFLES OR FLAP OUT OF THE SNORKLE LONG BEFORE I PUT THE KN ON
AND I DIDN'T HAVE THE BOG UNTIL I PUT THE PRO DESIGN KN ON. WELL WHICH IS
IT DO I JUST RAISE THE CLIP ON THE NEEDLES OR CHANGE THE MAIN JET FROM 140-145
TO A 145-150 SET UP. I PLAN ON DOING THIS SATERDAY SO ALL INPUT UNTIL THEN
WILL BE APPRECIATED.
THANX
01 BLU 660R
Old Jul 30, 2001 | 04:27 PM
VMAX12's Avatar
i just talked to Tom at pro-design. he said first to try the needles by raiseing
the clip one notch. if that don't work i should go up one size on the pilot
does that sound like a plan?
01 blu 660r
Old Jul 30, 2001 | 06:08 PM
ridnwarrior's Avatar
Usually bogging out or a hesitation is caused by a lean condition. If you're putting around the yard I'd say a pilot jet but if you bog out under a hard acceleration than go up on the main jet. Leave the needle clip where it is set.
Old Jul 31, 2001 | 03:58 AM
MagicMatt's Avatar
Left carb 145 Right carb 150 mains, 25 pilots (27.5 when you get a pipe).
Customer Service #1
May 15, 2020 08:46 AM
1ArmBandit
Sep 8, 2015 08:59 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Brandon400
Sep 5, 2015 08:44 PM
JakeXBL
Sep 5, 2015 01:08 PM
