NEED JETTING ADVICE WITH THESE MODS???
i just installed my pro design filter with the KN filter and outerwears
and i also cut the baffles out of the snorkle on my RAPTOR. when i tOok it for a ride
today i noticed a little low end bog. has anyone install these mods my exhuast
is stock. i need some jetting advice i know how to do it just don't want
to do it more than once. so what are the correct jets???
THANX
01 BLU 660R
THANX
01 BLU 660R
Since your running stock exhaust. I would say go up about 1 or 2 sizes on the main jets. Take the 145 main out of the right carb put it in the left one and get a 150 main for the right carb and see how it feels. You can also pull the baffle out of the stock exhaust for a little more flow. Kind of a pain without a torch but it can be done. Hope that helps
I agree with pineman, raise the needles a notch and see what that does for you. You MAY have to rejet but your bogging problem is needle or pilot jet/mixture related not main jet related.
By the way, I've noticed a lot of people having low end bogging problems when the remove the air baffle. Remember a big open free-flowing intake isn't exactly the hot ticket to low-end power. I think what causes the problem is there is less restriction going into the carb which means LESS VACUUM. Less vacuum means you are going to have a harder time drawing fuel out of the float bowl... That's just my analysis for what it's worth.
I CUT THE BAFFLES OR FLAP OUT OF THE SNORKLE LONG BEFORE I PUT THE KN ON
AND I DIDN'T HAVE THE BOG UNTIL I PUT THE PRO DESIGN KN ON. WELL WHICH IS
IT DO I JUST RAISE THE CLIP ON THE NEEDLES OR CHANGE THE MAIN JET FROM 140-145
TO A 145-150 SET UP. I PLAN ON DOING THIS SATERDAY SO ALL INPUT UNTIL THEN
WILL BE APPRECIATED.
THANX
01 BLU 660R
THANX
01 BLU 660R
Usually bogging out or a hesitation is caused by a lean condition. If you're putting around the yard I'd say a pilot jet but if you bog out under a hard acceleration than go up on the main jet. Leave the needle clip where it is set.
Customer Service #1
May 15, 2020 08:46 AM
