my warrior doenst want to start!!
Old Aug 8, 2001 | 12:16 AM
Guest
Guest
Posts: n/a
i have a 2000 warrior and it doesnt want to start. when i press the start button the celnoid just clicks. i bought a new battery and it still does the samething. SO ITS NOT THE BATTERY!! i got the starter tested and it works fine what wiring could be causing this or is something shorting out. i checked all the fusses the are all fine.
thanx for reading this!
Old Aug 8, 2001 | 01:59 AM
bayou220atv's Avatar
it is probably either your starter relay, or your neutral relay. I can't tell you anymore because i don't know the setup of the wiring on your warrior.
Old Aug 8, 2001 | 11:57 AM
RobS's Avatar
Check the connections on the battery again, clean them and put a little wd 40 on them. Follow the ground wire from the battery, remove it and clean the connection up( i think it is ground on the engine ). It just sounds like it is not getting enough juice. You may also want to try jump starting it if all that fails. Hate to see you look to hard, just to find the new battery wasnt fully charged at time of purchase. Hope this helps you some.
Old Aug 8, 2001 | 02:03 PM
IceMan11's Avatar
This could be a couple of things... Try doing this (I had the same problem with my Warrior). While holding the start button, reach back and wiggle the celnoid up and down. The got my bike going every time.
My guess is that you're not getting a good connection somewhere. You might want to take your battery out and clean off all the terminals on it.
2001 Yamaha Raptor (GYT-R Bumper, GYT-R Graphics, DG Skid Plates, Pro Design Kill Switch)
1988 Yamaha Warrior (too many mods to list... FOR SALE)
Old Aug 8, 2001 | 05:05 PM
Billibong's Avatar
it's your silinoid.
Old Aug 8, 2001 | 07:46 PM
RynoThePirate's Avatar
15mins ago i went to ride my 91 warrior and it did the same thing i was like whoa i just read on the forum somthing bout that.Does it just buzz? and click?
Old Aug 9, 2001 | 10:58 PM
juniortolliver's Avatar
get a celnoid i have one it did the same thing wfat we did was run a wire from the battery and one from the celnoid and tuch them together and it shoud start
Old Aug 9, 2001 | 11:06 PM
or you could run a wire from the battery directly to the starter...
Old Aug 10, 2001 | 06:26 PM
Guest
Guest
Posts: n/a
my celniod just clicks
how much would a new celnoid cost for a 2000 warrior?
Old Aug 11, 2001 | 12:38 AM
it will cost about $42 i chect on one
