RAPTOR w/oil seeping out of dipstick-HELP?
Old Aug 11, 2001 | 12:01 AM
joelpolaris's Avatar
Im trying to help a buddy with a Raptor. He has a problem with oil pushing out of the dipstick. The seal is good on the dipstick, but oil seeps out after riding for awhile. He says he followed the Manufacturers instructions for changing the oil and he is a mechanic so I believe he knows what he is doing. He said the clutch seams to slip once-in-awhile too. I was wondering if a worn clutch could be clogging the filter with shavings, restricting oil flow? Anyone else had this problem or have any ideas? He said he was going to try changing the oil again(its due).
Thanks.
Old Aug 11, 2001 | 12:41 AM
DuneJammer's Avatar
He still does have the O-ring right? If you loose that, you will leak oil.
Old Aug 11, 2001 | 01:41 AM
Raptoryfn660r's Avatar
RIP Dear Friend
If he tightened the dipstick to tight one time it could deformed slightly allowing oil past the seal. Going by mine it doesn't have to be very tight at all to keep the oil in. Chet
Old Aug 11, 2001 | 01:53 AM
I believe the O-ring was ok. I will check it again tomorrow. I believe it is building up pressure in the reservoir and pushing past the O-ring. But I will look again. Any other ideas if the O-ring is ok?
Old Aug 11, 2001 | 02:00 AM
scottd's Avatar
Maybe it's OVERFILLED with oil. The level changes drastically between hot and cold.
Old Aug 11, 2001 | 02:54 AM
RIP Dear Friend
If he has put in 3 qts. its overfilled.
bmxatv10
Oct 14, 2022 06:23 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
